Replacing frame struts.
Old 11-24-2015, 09:18 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
Default Replacing frame struts.
I had my frame struts cut off so I could do a swing arm mounted fender. My wife has never wanted to ride with me till recently so I was thinking I could buy some bolt on struts so I can use my old stock fender and 2 up seat. I am having a hard time finding bolt on struts that are strong enough for a second rider along with the correct size to fit the stock 200 tire
Old 11-24-2015, 09:28 PM
musicnbikes's Avatar
musicnbikes
musicnbikes is offline
What year is your bike?
Old 11-24-2015, 09:43 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
2007 night train. I want to make a quick bolt on 2 up fender so my wife can ride.
Old 11-24-2015, 09:45 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
I don't need any lights or electrical to run threw the fender. Only thing I am still thinking up Is a rock guard. I am sure it won't be hard to fab up a rock guard that stays mounted with either fender bolted up
Old 11-26-2015, 06:29 PM
back again's Avatar
back again
back again is offline
Received 4,806 Likes on 2,123 Posts
Ultima parts has struts that will work
Old 11-28-2015, 08:57 AM
Ink83's Avatar
Ink83
Ink83 is offline
Tried to find a pic but can't, I got ahold of a rocker C two up setup. The detachable seat struts bolt straight up to the trains holes for the original strut covers. Just need to make up some blocks to go between the struts and frame as the rockers are a wider frame
Old 12-03-2015, 08:08 PM
JohnK-NJ's Avatar
JohnK-NJ
JohnK-NJ is offline
I cut my frame horns off my 2002 Fat Boy also. Could you post a picture of your bike? You could use a Heartland kit.
Old 12-03-2015, 09:07 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
I have the stock fender and seat so I wanted to be able to swap out fenders to put a second seat on for my wife to ride. Bolt on struts should give me that ability
Old 12-04-2015, 05:47 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,224 Likes on 5,405 Posts
Harley started using bolt on struts in 08...fender is the same back to 06..should bolt right on.
Old 12-05-2015, 08:53 PM
JohnK-NJ's Avatar
JohnK-NJ
JohnK-NJ is offline
I wonder what the inside with would be between the bolts on struts. It would be wider then they were originally, correct?
Quick Reply: Replacing frame struts.
