Went To A HD Performance Workshop
Trying to find some specs on this SE Tire Shredder option you guys are talking about. H-D website only has the Stg 1 110ci upgrade kits mentioned. I am about to pull the trigger on the SE 120R motor, but I want to compare performance numbers with this tire shredder kit to see if its worth the extra $.
I picked up the 2016 Screaming Eagle brochure and here are both of the 110 Stage 5 kits with dyno charts. The first kit is the "Race-Only" (non-emissions compliant version) and the second kit is the "Emissions Compliant" version.
Non-emissions compliant kit:
Emissions compliant kit:
When installing the non-emissions compliant version (race version).... it is at the dealerships discretion as to what they cover for warranty. The MOCO takes no responsibility whatsoever for it. The dealership I spoke to had mixed answers. The tool behind the parts desk said it was a standard one year warranty but the service guy said there was NO WARRANTY but that they would put down in writing they will warranty the engine only for 5,000km (no time limit on the mileage). This kit also voids any and all warranty you may have had on the bike previous to installation.
The emissions friendly kit allows you to keep your factory warranty or any other warranty the bike may have.
I was told the kit will work on any of the 103 engines (without splitting or boring the cases). It still does not compare to the 120R that someone else had wanted to compare it to.
Fuel Moto consistantly hits those kind of numbers for a lot less money
Those kind of numbers could be done easily
Another drawback I see is going to be the tune. The maps that HD has for download and available with the SE tuner need to be fine tuned. They are very generic and leave a lot to be desired. While the SE tuner is a very capable tuner, it still takes the right person to use it. Where places like Fuel Moto can send you a map (for the Power Vision you already have) that needs little to no adjustment whatsoever.
Good luck with whatever you decide, but judging from the responses folks at your dealership have given you I would be looking for another shop. You may try posting in the engine section and just ask for recommendations for shops in your area that do good work. You can't be the only one that's skeptical of your dealer.
These engines are plug and play now not like the evolutions of old where you had to measure cam end play, put clay on the cylinders to measure valve clearance, Mill heads to get higher compression, bore and hone barrels, time the spark, list goes on. **** you don't even need to press the cams into the cam plate anymore....
Fuel Moto 107 kit for me is about $5200.00 Canadian installed plus a 3,000 mile trip and fuel and lodging.
The performance 110 kit through Harley is $5,500.00 Canadian installed.
Both kits put out roughly the same numbers but the HD kit has a larger 58mm throttle body, high flow injectors and 110 jugs (not included in the Fuel Moto kits). Both kits are great and offer roughly the same numbers and I'm 100% positive the HD kit will be able to be bumped up higher with a good dyno/tuner shop (room to grow).
Personally, I'd like to see Fuel Moto build a 103 engine with these new lined 110 cylinders using their heads, 777 cam setup, 58mm throttle body and Hi-flow injectors and custom dyno tuning. I'm sure the numbers would be pretty good!
corey01
Exhaust System Topics
06-25-2008 11:48 PM
