Pogo style seat fit issues
I think so, took a while to get all the glue residue off though, i'm going to prep the plastic & paint it to match the frame colour, by retaining the bracket that fixes it to the rear fender with a thumb screw its very easy to remove for access to battery etc.
No horse in this event but love the look of spring saddles. But I want to answer Joe's question regarding the fake post... I took mine off when I relocated my ignition coil and didnt notice room for a real post to exit past the frame. Not that it cant be done. But it aint gonna lend it self like a hooker
This setup doesn't use the fake post. It attached to the frame in two places:
- Just below the front hinge of the seat mechanism, it attached with one 5/16-18 bolt into the rectangular backbone where it sticks out aft of the fuel tank. (It picks up the same fastener that secures the fuel tank.)
- Just aft of that, it picks up two of the four 1/4-20 holes in the frame block where the ground-strap is attached.
It looks like a post, but it's actually just a 4-1/2" shock.
No problem.
Here is a stock photo from V-Twin Manufacturing. I added the red lines and circles.
Two things about the comfort.
The seat itself, just talking butt comfort, is extremely comfortable. It's a nice cradle with enough cushion to reduce hard spots, but not soft enough to get that hot-cheek feeling that some cheaper cushy seats provide.
The riding position is dependent on the rider. I like to sit up straight, and I like to sit high on the bike. My legs are not bent much either. Surprisingly, The position is not as far forward as the seat makes it look. It's a big seat and the cradle is only slightly forward from the stock seat, but obviously higher. The position is old school, but gives a much better amount of control.
I'm 6'2". The stock Slim has a very low seat height, and the floorboards would push my knees up to just under my hands. If I were to keep the stock seating position, I would change to ape hangers.
As others have said, the pogo style setup does not actually place you any further forward than the stock seat, height obviously is more than the stock, I agree with SLV about the position of your knees on the stock seat, if you are tall then the tendency with the slim is that you feel your knees are up round your armpits.
I managed to get all the glue residue off the seat pan today & then started to prep it for plastic primer. I've sprayed loads of bike & car parts over the years with good success using rattle cans, but for some reason I could not get a decent enough finish on the seat pan, so think i'm going to get an off cut of automotive vinyl & cover it with that.
