It's build time...05 Springer Classic
#101
#103
#104
Joe and Redbeard...help!
I'm on this console thing and I want some input before I make an irreversible move.
Where the console hole needs to go there is a portion of the bracket that needs to be cut or grooved to allow the new bolt to slide in. I have a carbed bike, so the bracket may be different than on yours. See the attached pic for reference.
If you faced this, Please let me know how you handled it. If you have ideas, I'm wide open to suggestions. I'm loathe to start cutting this part.
It appears this will need to be grooved or removed at the bottom to allow the bolt to slip under the tab.
Thanks for any and all help guys.
Here's how I did mine - super easy to do with basic tools.
I used a 1/8" thick 1.25" wide aluminum flat stock, cut, filed, and sanded to shape, and mounted it with a couple 1/4-20 x 1/2" bolts, and a new full thread 5/16-18 x 1.25" bolt to mount the console onto.
All the hardware is available from Ace Hardware. Most Ace Hardware stores have a selection of chrome hardware too.
#105
I think mine had the same little tab and I didn't cut it for sure. I suppose it just bent out of the way a little when the bolt head pushed it down, frankly I don't exactly remember as I type this but for sure I didn't cut it.
The bolt I used had a pretty thin head, it wasn't a grade 8 bolt or anything. Maybe ¼" thick head? It was a standard bolt you get an a kit of bolts from HF or HD (home depot not Harley, they would want $3.33 per bolt).
#107
I didn't cut it. There is no need to either. Just mount your new bolt into the flat stock, and then mount the flat stock to the tank on those other two holes. As you tighten it down, the head of the new mounting bolt will push the tab you're asking about down and out of the way. It's not a big deal at all.
Don't cut it though - it provides some structural support to the two holes you're mounting your flat stock onto.
#108
Thanks for the advice guys. Bent the tab. That worked for that aspec. Can't believe I didn't think of that. Sales guy, not Engineer. But I had the coolest music playing while working on it.
Last bit in the way. A couple posts on the back of the console. Gonna cut holes in the bracket for them to go through. Then we've got it licked.
The little black posts beside the bolt.
#109
#110
Last bit in the way. A couple tabs on the back of the console. Gonna cut holes in the bracket for them to go through. Then we've got it licked.
Post a pic?
Oh and you need short screws to hold on the bracket, at least on the right side - I used a little loctite as I do with most screws on my bike.
