Softail Factory Wide Tire Kit
Old 02-07-2016, 02:11 PM
SirHarley's Avatar
SirHarley
SirHarley is offline
Cool Softail Factory Wide Tire Kit
This thread is for all those who chose to believe that wide was here to stay. Back in 1998 HD offered a "Softail Wide Tire Kit" OEM 43684-98.
Please post your pics. I didn't have digital camera back then. I'll try to dig some pics up and scan them into digital format. For Now, I only have a side view...Softail Factory Wide Tire Kit-1988-pontiac-bad-boy-3-.jpeg
Wide Tire kit PDF.pdf
Old 02-13-2016, 09:04 AM
SirHarley's Avatar
SirHarley
Cool
I'm posting this for all whom may be interested...Read, Read again, and do the research on your own!
70 Tooth OEM pulley (black) OEM 40217-79A
65 Tooth OEM pulley (black) OEM 40312-94
The 70 Tooth pulley uses a 132 tooth belt (HD OEM# 40023-86)
The 65 Tooth pulley uses a 130 tooth belt (HD OEM# 40017-94)
The 61 Tooth Pulley uses a 128 tooth belt(HD OEM# 40246-91) Only 1993 HD Softail 1 1/2" wide
The 1993-2003 up XL883 Sportsters had a narrower 61 tooth pulley OEM 40246-91 (1 1/8" wide) Use of this Pulley/128 Tooth Belt combination will allow a 150/80-16 Wide Rear tire. (OEM #43043-98) on all Softail's. Belt alignment must be checked during installation and proper alignment shims may be necessary under rear pulley per HD specs. I have installed this kit and no shims were needed. The kit came with a new narrower belt guard (top) OEM 60571-98 U will need one or trim the original belt guard. The V-Twin catalog line sells one Pt#VT-27-0242 (65 Tooth Wide Tire). I have driven over 25k miles on the thinner belt/pulley and there were no issues. All Harley Softail's 1984-1986 Use a 30 tooth front drive transmission pulley/sprocket. 1987-1999 used a 32 tooth front drive transmission pulley/sprocket. That part remains in the conversion. See Installation instructions (HD J01185 REV. 1-16-98). The Wide Harley Davidson Dunlop D401 150MM Tire Kit, OEM 43684-98 had a 1 1/8" wide 65 tooth rear pulley and a 1" 132 tooth belt. Now Discontinued and very rare. However the tires, belts, and belt guard are still available. The Dunlop K591 tire is a little more sporty profile and utilizes a softer rubber compound, but very similar in design to the Dunlop D401.
STOCK PULLEY SIZES AND BELT LENGTHS
Table gives stock pulley sizes and belt length for European models. Check OEM parts catalog for non-European models.
Model Year Front Pulley Rear Pulley Belt Width Belt Length
XL883 1993-2003 27T 61T 1 1/8" 128T
XL883 2004-2006 28T 68T 1 1/8" 136T
XL883 2007-2010 28T 68T 1" 136T
XL883 2011 to present, USA models 29T 68T 1" 137T
XL883 2011-2012, International Export Models 29T 68T 1" 137T
XL883 2013 to present, International Export Models 30T 68T 1" 137T
XL1200 1991-1994, USA Models 29T 61T 1 1/8" 128T
XL1200 1991-1994, HDI International Export 29T 55T 1 1/8" 125T
XL1200 1995-2003 29T 61T 1 1/8" 128T
XL1200 2004-2006, USA Models 29T 68T 1 1/8" 137T
XL1200 2004-2006, HDI International Export 30T 68T 1 1/8" 137T
XL1200 2007-2010 30T 68T 1" 137T
XL1200 2011 to present, USA models 29T 68T 1" 137T
XL1200 2011 to present, HDI International Export 30T 68T 1" 137T
XR1200 2008-2010 28T 68T 1" 137T
XR 1200 X 2009-2013 28T 68T 1" 137T
V-Rod 2002-2006 30T 72T 1 3/8" 150T
V-Rod 2007 to present 30T 72T 28mm 152T
Dyna 1991-1994, USA Models 32T 70T 1 1/2" 133T
Dyna 1991-1994, HDI International Export 32T 61T 1 1/2" 128T
Dyna 1995-1999 32T 70T 1 1/2" 133T
Dyna 2000-2005 32T 70T 1 1/8" 133T
Dyna 2006 32T 70T 1 1/8" 133T
Dyna 2007 to present 32T 66T 1" 131T
Touring 1984-1986 32T 70T 1 1/2" 136T
Touring 1987-1994, USA models 32T 70T 1 1/2" 136T
Touring 1987-1994, HDI International Export 32T 61T 1 1/2" 132T
Touring 1995-1996 32T 70T 1 1/2" 136T
Touring 1997-2003 32T 70T 1 1/2" 139T
Touring 2004-2006 32T 70T 1 1/8" 139T
Touring 2007-2008 32T 66T 1" 137T
Touring 2009 to present 32T 68T 1" 140T
FXR 1984-1986 32T 70T 1 1/2" 136T
FXR 1987-1994, USA models 32T 70T 1 1/2" 136T
FXR 1987-1994, HDI International Export 32T 61T 1 1/2" 132T
Softail 1984-1986 30T 70T 1 1/2" 132T
Softail 1987-1990, USA models 32T 70T 1 1/2" 132T
Softail 1987-1990, HDI International Export 32T 61T 1 1/2" 127T
Softail 1991-1992, USA models 32T 70T 1 1/2" 132T
Softail 1991-1992, HDI International Export 32T 61T 1 1/2" 127T
Softail 1993 32T 61T 1 1/2" 128T
Softail 1994, USA models 32T 70T 1 1/2" 132T
Softail 1994, HDI International Export 32T 61T 1 1/2" 128T
Softail 1995-1999 32T 65T 1 1/2" 130T
Softail 2000-2005 32T 70T 1 1/8" 135T
Softail 2006 FLST, FLSTC, FLSTF, FLSTN, FLSTSC, FXSTD 32T 70T 1 1/8" 135T
Softail 2006 FXST, FXSTS, FXSTB 32T 70T 20mm 135T
Softail 2007 to present FLSTC, FLSTSC, FXSTD, FLSTN 32T 66T 1" 133T
Softail 2007 to present FLSTF, FXST, FXSTB, FXSTC 32T 66T 20mm 133T
Softail 2008-2011 FLSTSB 32T 66T 20mm 133T
Softail 2008-2011 FXCW, FXCWC 32T 66T 1" 133T
Softail 2012 to present, all except FXSB 32T 66T 24mm 133T
Softail 2013 to present FXSB 32T 66T 24mm 133T
Attached Thumbnails Softail Factory Wide Tire Kit-a20791b1291c238d5749e4_l__30596.1415374106.386.513.jpg   Softail Factory Wide Tire Kit-pimg0866.jpg
File Type: pdf
File Type: pdf
Old 02-13-2016, 09:15 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,199 Likes on 5,396 Posts
Old 02-13-2016, 10:22 AM
SirHarley's Avatar
SirHarley
Gone Already...!
Somebody knew what that kit was worth. But you can still get all the parts you need. You just have to purchase them separately. That wasn't a bad buy it now price either...Slightly under what I paid for mine back in '98 with my HD VIP discount!
Old 02-13-2016, 05:24 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
I didn't use a kit on my 94 softail...picked up a 1" or 7/8" belt...not sure what it was an a matching used pulley an put a 170 on the back of my 94 softail. Guess I'm out of style because I like as wide a tire as you can fit...that's the only thing I don't like about the slim S.
Old 02-13-2016, 07:27 PM
SirHarley's Avatar
SirHarley
Cool
It had to be a 1" wide belt. Narrower, and any hole shot would have snapped your belt in short order. Is that a stock fender? Most guys dont want the extra expense of new sheet metal, and hiring a custom painter.
Heres a look at my wide kit from behind...I'm still looking for a better pic.
Jesus Saves Lives...Loud Pipes Just Sound Cool!
Old 02-14-2016, 11:04 AM
tgaetto's Avatar
tgaetto
tgaetto is offline
So all I need to do is the pulley and belt? No spacer? I remember on my y2k I had to space the pulley to fit a 150...
Old 02-14-2016, 01:12 PM
SirHarley's Avatar
SirHarley
Cool
Yes. Absolutely check the spacing in the new pulley. Read the instructions I attached to my threads. Specifically step #16.
Old 02-14-2016, 07:49 PM
langwilliams
I had to space my pulley to clear the tire. I think I have one in the garage now. I got 2 sizes to test fit.
Old 02-23-2016, 12:23 AM
tgaetto's Avatar
tgaetto
tgaetto is offline
I think I am going to find a 1" set up, I am going to run 18 x 4.25 rear with a 150. Any tips for removing the primary? I seem to remember using a cut piece of 1 x 2 or maybe it was a steel shim to lock up the primary to crack the nut loose on the front sprocket and basket. Is there any benefit to changing the tooth count? What will a 70t turn as appose to a stock 65T will it even work with a 130 tooth belt or do you need to get something else? I am just asking because I'll be in there.. Not sure I'll do the wheels until next winter since the rubber is good on what I now.
Quick Reply: Softail Factory Wide Tire Kit
