Fxst
Old 02-11-2016, 12:41 PM
Tazmaz4's Avatar
Tazmaz4
Tazmaz4 is offline
1st Gear
Talking Fxst
Looking to see what tires and wheels will fit the 03 FXST front wheel from the stock skinny one with little modifications
Old 02-11-2016, 03:15 PM
byersmtrco's Avatar
byersmtrco
byersmtrco is offline
19" mag wheels came on early FXWG's (81-ish)
Similar forks (dual Disc)
Those spacers might work (19" spoke whl too)
Old 02-11-2016, 05:40 PM
djgdot's Avatar
djgdot
djgdot is offline
Old 02-11-2016, 06:57 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,201 Likes on 5,397 Posts
Virtually any softail front wheel from 2000-2006 will bolt on using the correct spacers for that wheel...pick what ever size you want. If you plan to run a front fender you have to buy one designed to run a fat tire with an FXST front end..tons of manufacturers make them. For example, if you run a fatboy front wheel...you cannot use a stock fatboy fender because the mounting points are different on the FX front end...but you can get several aftermarket fenders that will fit that combo.
https://www.google.com/search?q=16%2...r+fxst&imgrc=_
Jgrasham
09-04-2016 07:54 PM
Chrome Wench
09-17-2015 11:41 PM
DR. V-TWIN
05-27-2010 09:47 AM
lilsahara450r
03-19-2010 04:46 PM
Quick Reply: Fxst
