Stage 1 upgrade
Stage 1 upgrade
I have just bought new Vance Hines big shots and k&n high flow filter kit. My question is if I put these items on my bike can I drive it aprox 10 miles to the dealer to have the fuel system remapped with out hurting the bike, or should I just take the parts to the dealer and let them do it????
Myself, I would put the parts on and order a tuner with the maps done up for the parts. Either from Fuel Moto or whoever. I would not get the dealership to tune my bike. I'm also rather **** and would advise against riding the bike without the proper tune installed for your Stage 1. I'm sure 10 miles won't hurt it much but why chance it? Especially if the bike is new and not really broken in yet. JMO
Riding 10 miles won't hurt it at all.... you'll be lean so just don't beat on it....
Some will say the ECM will adjust for the change and no remapping is needed. That is true, to a point...
These bikes are lean from the factory to appease EPA requirements, so I would remap as soon as practical.
For what it's worth, almost all the HD downloads (remaps) are still EPA compliant and on the lean side.... If you are planning on other mods down the line, for about the price of 2 HD downloads, you can buy a PowerVision tuner and have access to just about any map you'll ever need. And they won't be lean EPA maps..
Enjoy....!
Enjoy....!
So from experience the dealer reflash won't do much especially if you change the exhaust. Actually it will most likely have tons of backfires when decelerating. Personally instead of paying 200 for the dealer flash get a power vision or power commander from FM and they can load a map in for you that works well. Either choice would be about 3 bills.
Another option is to find a good dyno tuner in your area and have them optimize your bike for the way you ride.
Speaking from experience here. I did slip-ones and stage 1 AC on my own and used the street tuner from HD. I had TONS of decel popping. When I did my cams I went with a power commander V and a dyno tune. It never ran better even when stock. If I were to do it all over I would personally go with a power vision and target tune so as to keep the adaptive fuel and closed loop operation
I'm in agreement with Berick. A Stage 1 is a simple job. Do the work yourself. Additionally, if you have your dealer Tune the bike they will do so using Harley's Scream'in Eagle Race Tuner (SERT) which in my opinion is the worst device on the market. Investigate tuning it yourself with either a Power Vision, or V@H's new FuelPak. Both devices have capabilities beyond that of the SERT.
get a Powervision from FuelMoto, or a Fuelpak FP3 from V&H. way better place to put your money than the dealer's tune.
Good luck!
Received 3,940 Likes
However, as most have said, you will be better off with a Power Vision or an FP3. You will get far more for your money and a better tune, now and later.
You can read more about both of these easy to use tuners HERE.
The first post in the following thread also has a good overview of all tuning options (including the dealer option)-
https://www.hdforums.com/forum/ignit...uning-etc.html
