Fuel injectors-Bike spitting back
Old 02-21-2016, 08:01 PM
cgmartine's Avatar
cgmartine
cgmartine is offline
Cool Fuel injectors-Bike spitting back
Is is possible for a fuel injector to slowly leak fuel into the cylinders when a motorcycle sits overnight or for a few hours? I have a 2006 fuel injected Softail Heritage Classic. Sometimes, but not every single time, when I start it, after it has cooled or been sitting for a few hours, it spit backs, but then starts up immedidately. It is sort of a like a back fire. Is there any chance it could be the injectors? It still has the old injectors and I have been thinking of replacing them with the injectors called for in the recall notice. Any ideas?
Old 02-22-2016, 05:47 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
Yes, fuel injectors can leak, but if they were, you'd probably be getting a lot of black smoke on startup.
Old 02-22-2016, 07:31 AM
FLS103's Avatar
FLS103
FLS103 is offline
Does it sound kind of like a sneeze? Could be a bit lean
Old 02-22-2016, 08:55 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
something is definitely not normal there- Try posting this over in the technical area fuel injection and tuning thread- you'll get more of the right eyeballs on it. I'm surprised you have not upgraded the recall injectors yet- you might want to do that regardless.
Old 02-22-2016, 10:54 AM
Warp Factor
Harley will only replace the injectors if they can confirm running or driveability problems. Mine's always run fine, so no new injectors.
Old 02-22-2016, 11:36 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
ahh yep- thanks for the comment on that. I see that it was only a service bulletin and not a full on recall- so no love from HD unless rideability issues were noted. I don't see how the OP can figure this out though without going in for diagnostics / nothing is coming to mind on the DIY side.
Old 02-24-2016, 01:48 PM
cgmartine's Avatar
cgmartine
If its is an issue of it running lean, since it does not have a carburator, can they calibrate the fuel injectors? Also, I do not have a stealership nearby, but I do have two small motorcycle shops, do most of them have diagnostic equipment on hand?
KBFXDLI
09-15-2010 09:15 PM
TAC1
07-19-2010 10:08 PM
grumpy56
06-28-2009 11:10 PM
ggold
12-24-2006 11:15 PM
needadyna
Exhaust System Topics
02-16-2006 09:13 PM
Quick Reply: Fuel injectors-Bike spitting back
