Fuel injector issue
Fuel injector issue
Have 05 heritage FLSTCI having injector issue Only the rear cylinder firing . I removed the injectors and verified they are clean and tested them with by connecting them do a carb cleaner and battery to verify it fires. I do have spark at both cylinders. I do have P0262 Front Injector High engine code. I have also used the screwdriver listing device and verified the front injector is not tapping while the rear is. Can I switch the injector leads between the front and back to see if the issues follows with damage or will I have to swap the injectors themselves?
rh1212
Exhaust System Topics
03-19-2011 02:15 PM
