Rocker B: MY ROCKER C MOD THREAD
#432
If he was to swap the Rocker axle for a Breakout axle he will need to swap the left fork leg too. Right side diameter is the same. I used a chromed right fork leg of a Rocker on my Breakout...the left fork leg of the Rocker would not fit due to a larger axle diameter compared to the Breakout. I had to buy a CVO fork leg instead....very pricy.
But you're the one who can tell for sure having both bikes in stock
#433
I found the thread I had remembered seeing https://www.hdforums.com/forum/softa...my-rocker.html HHI makes an axle, without the step down (2nd pic, HHI bottom/Breakout top) that works on Rocker forks with a wide triple tree, or you can use a bushing on a Breakout axle, like Alain did (1st pic) while he was waiting for the HHI axle to show up....So, Valdemar you wont need a new left fork to install a Turbine wheel on your Rocker...... and Ray, I guess you could have used both Rocker C forks with the HHI axle, or your BO axle with a bushing, and saved a few bucks, not sure if it would have been a lot cheaper though??......
#434
Thank you friends for help...
It´s a problem the wide size of the breakout wheel, because a lot of work and money for chagne the triple trees.
I think continue with my Rocker C wheels in the future...A new custom chrome wheels specifically for rocker are very expensive compare with the breakout wheels.
#435
The painter called this a.m. He's been really busy, and just got started on my job. He wanted me to come take a look at the Thunderbike fender. It turns out it's gonna need some body work to look it's best. There are some fairly minor imperfections that are noticeable now that it's primed. It'll add a couple hours labor to the job, .... but I really think it needs it, again, it's not bad, someone else may have just had him paint it, but seeing a wave in the new fender would bug the **** out of me!! He said he should have everything done by the middle of next week.....
#436
The painter called this a.m. He's been really busy, and just got started on my job. He wanted me to come take a look at the Thunderbike fender. It turns out it's gonna need some body work to look it's best. There are some fairly minor imperfections that are noticeable now that it's primed. It'll add a couple hours labor to the job, .... but I really think it needs it, again, it's not bad, someone else may have just had him paint it, but seeing a wave in the new fender would bug the **** out of me!! He said he should have everything done by the middle next week.....
#437
#438
Yes, the front was good to go!!
#440
I finally got around to installing the HD flush mount gas cap and fuel gauge!! They look and fit way better then the Drag Specialties cap and dummy cap that didn't match (different diameters) and had a sloppy fit (lose and didn't sit flush on the tank). The gas cap also leaked when the tank was full.
Here's the Drag Specialties cap and dummy cap I replaced....
Here's the HD cap and LED fuel gauge....The fit and finish is much better....and I like the fact that you can't see the indicators on/in the gauge, unless the lights are on, it just looks chrome with the lights off ....the fuel gauge also has a photocell, so it dims the fuel pump icon and fuel level LEDs in low light conditions....
