What length cables for 17 inch apes
Old 04-14-2016, 12:36 PM
Stlavsa's Avatar
Stlavsa
Stlavsa is offline
Stage IV
Default What length cables for 17 inch apes
I ordered some prewired bars w. New controls for my 14 slim, had to also pickup can bus adapter. I still need the cables. Anyone know the length? Do I just need to measure once bars are on there? Thanks
Old 04-14-2016, 07:34 PM
FLS103's Avatar
FLS103
FLS103 is offline
How you route the cables, bar height, riser height and bar width all determine cable length. Best to mount bars and use an old peice of extension cord to get your lengths. Then you know it will work.
That being said...I ended up with +8" idle & throttle and +10" clutch with a 1.125" riser, 16" bar height and 37.5" width on my 2013 Slim.
Old 04-15-2016, 05:29 PM
Stlavsa's Avatar
Stlavsa
Stlavsa is offline
Stage IV
Thanks for the help. I figured all the configurations would change lengths. I just wasnt sure how to measure. Good call on using an old extension cord.
So next question and it might be dumb. We're youre cables the exact length you ordered? From tip to tip?
Old 04-15-2016, 07:27 PM
FLS103's Avatar
FLS103
FLS103 is offline
Clutch cables are usually measured in total length, you also have to keep the position of the adjuster in mind. Idle/throttle are measured by housing lengths, you also have an option of tube bend where it attaches to control housing 90° or 45°....most people use 90°. Brake lines are total length. Magnum shielding used to have a good explanation on their website.
Clown Shoes
03-23-2022 03:49 PM
ctfzr
10-16-2012 01:31 PM
rootbeer
06-29-2010 03:36 AM
Longtimegone
05-15-2006 11:31 PM
tommylee
01-27-2006 01:21 PM
Quick Reply: What length cables for 17 inch apes
