Under seat pics of PCV with Autotune?
Old 05-01-2016, 12:40 AM
Thet's Avatar
Thet
Thet is offline
Default Under seat pics of PCV with Autotune?
I can't for the life of me cram everything under the seat. Anyone have tips or trying? I also don't think my Saddleman seat has as much room as stock...
Old 05-01-2016, 08:14 PM
Kburgad's Avatar
Kburgad
Kburgad is offline
You have to have the softail ecm bucket, I've got my pcv on my ecm. Then the auto tune module in front of the battery between the cables, I have the single module setup. Just had my seat off today. I'll post pic l8r if I can get my daughter's to bed at a decent time.
Old 05-01-2016, 09:34 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
Thet, where you stationed? I am stationed at Scott and a fellow ammo guy as well (noticed the **** pot)
Also dyno jet makes a ecu tray to help fit everything if you can't make space
Old 05-01-2016, 10:29 PM
Thet's Avatar
Thet
Thet is offline
I'm separated. Was stationed in Okinawa and Vegas. I'll look into the tray. Thanks!!
Old 05-02-2016, 10:09 AM
Thet's Avatar
Thet
Thet is offline
Does the softail tray require you to cut into the fender?
Old 05-02-2016, 11:42 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
No cutting involved.
It is only 1/2" deeper than stock so don't expect miracles.
Old 05-02-2016, 01:02 PM
Thet's Avatar
Thet
Thet is offline
What I'm not getting is the ECU bracket was already removed... per the instructions. I don't see how this will create any new space.
Old 05-02-2016, 08:23 PM
Kburgad's Avatar
Kburgad
Kburgad is offline
Did you get the deeper ecm tray already? If you have it the pcv gets zelcroed to the fins of the ecm and they fit under the seat. I'll go take a pic of my setup and post it for ya.
Do you have the dual module auto tune or the newer single?
Old 05-02-2016, 08:54 PM
Kburgad's Avatar
Kburgad
Kburgad is offline
Pcv is usually ziptied to the pcm but I've been trying to clean up the mess of wiring
Auto tune tucked between the frame grounds and battery cables
Old 05-03-2016, 04:03 PM
Thet's Avatar
Thet
Thet is offline
I managed to get it all to fit. I had the wrong instructions for my model. Apparently, the 08 Fatboy needs the 09+ Softail instructions.
I did not use the tray. It wouldn't have done anything.
Quick Reply: Under seat pics of PCV with Autotune?
