I put 2013 v rod muscle wheels on my 02...the 13 had 25 mm an the 02 had 1". you can go to a bearing supplier an find the correct inside diameter ones. You can probably run a 25 mm front axle an spacers, a lot of v rod guys do this. some use 1" bearings in the newer wheels an just space them. the pocket depth is a little different but they make it work, might need a chrome cap to cover the spacer an any bearing that sticks out or is recessed.
