any trick to removing the clutch hub nut?
Received 4,614 Likes
I've used an impact wrench, came off easy. If you don't have an impact wrench, heat it up as much as you can; one of those 800 or more degree heat guns works well, softens the high strength locktite that nut is supposed to have on it. Some guys use propane torches, but I don't like flaming that area. One of those tiny pencil torches might work ok. It's probably the locktite, not the torque, that is so difficult to break loose, especially if whoever put it on poured on all the locktite that wouldn't drip off. A couple drops is sufficient.
Oldtigercub
08-12-2011 09:12 PM
