Rush Slip-On Change On My Heritage!
I have Rush 1.75 slip on's on my bike. I currently have about 42K on the bike and I put the slip-on's on not long after I got the bike so maybe 2K. It has gotten a bit louder over time and the Harley growl is well pronounced. Mine and the wife's boots has taken a toll on how they look so I have been considering replacing them but I'm not sure with what yet.
I've been running Rush slip-ons with the 1.75" baffles and find them to be quite loud, with a real "crack" to them under load.
This is on a 117 engine with cams, etc.
They were never quiet, even when new. I like the sound and it seems the performance on the butt dyno is more than adequate.
If you feel they sound right, use them, they're good pipes and so far you're only cost has been a set of baffles.
There are other materials available for wrapping baffles if you desire a quieter note.
I put the 2" rush slip-ons on for my stage 1+ (custom dyno tune). At first I thought they were to loud so I bought the 1.75" baffles, I hatted it. The 1.75 baffles took the base tone out and just end up with the cracky higher pitch sound, hated that and it wasn't all that much quieter. I put the 2" back in. So if you want the more cracky sound verses base tone the smaller baffles are for you.
Packing gone, are you sure the previous owner didn't cut it off? A common thing to do.
I didn't see where you stated any mods other than the slip-ons... You need to decide how loud you want the bike to be. 2.25" baffle will be louder than a 2" baffle. A bike with upgraded cams will be louder than stock. Personally, I like my 3" Rush tubes as they don't overwhelm the bike's back end so much. To each their own. I've had two different Rush setups and can say the chrome is excellent and lasts. Good luck in your search.
Unknown if the previous owner cut off the fiberglass packing. There was not a trace of packing material around either baffle, so it is a good possibility. Gosh, I hope I don't get a cracky sound. I just want some more back pressure. Hmmmm, I just installed them yesterday and it started to rain so I have not even started the bike yet with the new baffles. I will find out today.....
Thanks,
Phil
As a general rule of thumb, the larger the tube, the deeper the rumble. Think of any wind instrument, the larger the lower tone....
Thanks,
Phil
I got my 2"ers at the 1K service,, now 9yrs later and with 53K I still really like them.. I have rewrapped them twice. when they've gotten louder,, you can tell when it's time..
I'll add even when they need rewrapped their will be about 75% of the old matting on the baffles.
If your baffles have None at all,, then IMO someone removed it
Also they have went to a two layer wrap install several yrs back that puts the overlaps at 180* to each other instead of just one overlapping piece of matting like they did when I got mine and now they should last longer..
The first two times they burned out,, it lost the matting was where they overlapped...
over all I am totally pleased with them.
