Brakes, Is this normal?
I got the calipers out , I press the brake lever and the piston only travels 1/4" ,
I don't see any leaks, I looked and confirmed the mc is full of fluid.
What is my next move? Empty out fluids pull out the piston, clean the inside?
The rubber seal around the piston looks pretty fresh not old and cracked.
Think the retainer wire 13 is a small spring wire that puts a small load on the dust boot. Fits in that first small diameter on the boot. Caution..My picture is a 97 softail. You should not be learning how to do brakes on here or unsupervised by a qualified teaching mechanic that is present!
Hook it back up and use the master. How I do it before removing. Just part of getting new fluid thru. Put block of wood in front of it if you use air or the hydraulics.
OK I have the piston outs, are surely everything looks great the piston has no scoring the seal is nice. I am guessing the reason it was not pushing out Was maybe because there was air in the lines? Maybe I should've bless line before I took it apart. Unless anyone can think of another reason why it was not pushing out?
Yes air compresses unlike brake fluid. Be sure the piston is smooth and no pitting. However, also make sure the groove in the caliper where the piston ring sets down in (not the dust seal ring) is smooth and no pitting. Both walls and the bottom of the groove. (use a small dental mirror to check back side)
