Front fork lowering kit need some advise.
i looking for 2" front fork lowering kit. i found 2 set progressive in Ebay which different kind by words "Progressive Drop-In Fork Lowering Kit" and "Progressive Fork Lowering Kit" as the picture below.
please suggest what's different and which one better? or another way lowering are welcome.
Thank you for advance.
Couple of tid bits.
You can use schedule 40 PVC pipe from the hardware store to make different size spacers.
Make sure you compensate with less fork oil to make up for the lowering of the forks and space that the spacers take up. Too much oil will blow your fork seals and you front end will be way to stiff.
Ricor Intiminators and Pre-load adjuster caps are a perfect addition to this project.
I have done this a couple of times before with lots of trial and error.
Mono shocks would be a better choice. Cheaper in the long run and a hell of a lot less work.
