Satin finish scratch repair
So... I decided I preferred my bike without the sissy bar.
But in taking it off, the inevitable happened and there are some small (but massively noticeable to me) scratches on the rear fender
It's the charcoal satin paint, so what's the best way for me to repair it?
I've never used touch up pens before, so not sure how they work - will using one and buffing it make the finish go shiny?
Any advice much appreciated!
Bear in mind I'm in the UK so any products you might recommend I may not be able to get hold of
IMO I would seriously assess how much this needs to be in fact re finished. The touch up pens or paints will always be noticeable, maybe more so than the current issue you have. If its down to the metal it may be needed to keep rust away. If its truly bad enough then a complete repaint is an option. But bear in mind unless the piece is expertly painted there could be finish/match problems with that.
Does Harley offer the parts pre-painted? if they do you could bite the bullet and replace if it bothers you that much, which I do understand if it did.
