Bouncing slow speed braking 92 FLSTC
I have a 92 FLSTC that bounces or throbs at slow speed braking. This bike is new to me (three weeks / 450 miles). It has a lowering kit and I noticed this after it was put back up to factory height. However, I did not ride it much before that.
My theory is that putting the rear back up to factory height effectively stiffens the rear and puts more pressure on the front shocks and causes them to bounce. Possible?
If so, is there a solution? Front shocks are not adjustable, correct? Is it possible to put a new spring in the front to stiffen it?
Or is my theory off base? Is it more likely to be related to the brakes? Or is this normal softail braking?
I would think a bike that's 24 years old and been ridden probably has a lot of worn out parts especially the suspension.
There are front suspension kits out there that people on this forum seem to like.
Progressive Monotubes comes to mind.
http://www.progressivesuspension.com...u-2013-touring
As for the rear, I have a hard time thinking that the shocks if not already changed out are probably worn out.
Again there are some aftermarket ideas out there but they are limited.
Progressive 422 and Shockgun Shock Air suspension come to mind.
Sorg67 (05-29-2016)
I thought something with brakes at first, but it does it either front or rear is applied which made me think it was a suspension issue.
Received 14,139 Likes
Check the fill level of your forks as well as the viscosity used. Tire pressure comes into play with this as well. Would not hurt to check your steering head bearing / adjustment/ grease.
Flush all your entire brake system with a lot of fresh fluid.
For the rear shocks, I am very happy with a Works Performance light duty.
Join us in the Evo section.
+ 1 on what Prot said...
I flushed my front tubes at 30K.. book say's 50K.. or every 5yrs or so... I also went with one weight heavier than stock to firm it up a little.. not the Heaviest just the middle weight
HD fork oils..
type e - 5 wt (standard for showa forks)
type b - 10 wt
se heavy - 15 wt
se race - 20 wt
My INDY uses Bel-Ray.. I think it was the 10W he put in.. a bit firmer over the Type E-5W that came in mine new..but after a few miles I liked it..
http://www.belray.com/bel-ray-high-performance-fork-oil
HD fork oils..
type b - 10 wt
se heavy - 15 wt
se race - 20 wt
