2012 Fatboy gear change issue
Hi Guys, hope you can help, i have a 2012 Fatboy and yesterday nearly home i realised i could only get 2nd and 3rd gear, i pushed my heel down on the shifter but it was all the way down
When i got home i looked at the shifter linkage and noticed it was very loose and i could move it right and left quite a way, (forward and backward)
It seems that maybe the gear shift is going down for 3rd but not returning so i can select 4th
Any idea what might be the issue?
Thanks for any advice
Cass
Cass
I was just lookin at this earlier. Worth checkin out...
http://www.fixmyhog.com/video/harley...issues-008726/
Hi Cass,
Could be the pinch bolt has worked loose allowing the shifter lever to move on the splined shaft. From the amount of play you described it could be that the splines have worn, I hope that's not the case though.
I do remember another thread somewhere on another forum mentioning an after market fix if indeed this is the problem with yours.
Gary
Gary
Hi Guys, i really appreciate the feedback, i have made sure everything is tight so will wait till the Harley dealer picks it up on the 16th, but cant look at it til the 20th
Not ridden it since the end of May in case i make it worse, i thought as i can get up to 3rd gear i could ride around town but i guess i could be doing more damage, so no riding for me in this lovely rare hot weather in the UK.
Cass
Cass
