New to me 2008 FXSTB
I've been hanging out in the touring section for the past 10 years or so but recently acquired a night train. I'll share some pics and also share my experience with the so called "easy" lowering kit.
This is a before:
During the install of the lowering kit, I realized it would be easy if I had lift rather than a jack. Or, have three hands the size of 5 year old. Because I have neither of these, I removed the rear shock mount bolts so I could move the shocks back and install the collars. Of course the right side bolt is a PITA and to make matters worse, during the install, I cross threaded it. I had to remove the swing arm to able to rethread it.
The end result is this:
This is a before:
Thanks. I didn't use bolts, just added collars and they would be easy to install if you use a lift, jack (for the rear tire) and have an extra set of hands. I didn't notice too much of a difference in the ride. I'm not lowering the front. The only reason I lowered the rear is because of the gap between the fender and tire, It just didn't look right to me.
http://www.ebay.com/itm/La-Choppers-...-/331521998195
