Newbie! 1996 Springer - Modifications question
In the rear, 160 is as big as you are going to go without spending some money...if you want to bigger might as well go 200...you can do that for the same price as 180.
In the front, you are not going to get anything in there that makes a noticeable difference and keep the front fender...nobody makes a wide fender for an FX springer.
yes Lang 1" belt. 2003 stock spoked wheel,03 pulley and used star nuts to mount fender.
Used the spacers from the stock 96 set-up. Bought the wheel,pulley off classifieds on here for 100.00. 50 to powder the spokes and a new Metzler. Pulling the belt took a couple hours and really is not difficult. Ends up with a 1/4" clearance between belt and tire with this set up.Everything is straight forward bolt on and rubs nowhere. Dunlop 160 tires are a 1/4" less in width from the Metzler I've found. G.
Thanks MUCH!!
I was told how great the HD forums was but I was not prepared for really how great it is.. THANK YOU ALL!! Very much... I'm getting so much valuable info and as a newbie you can't believe how important that is.. I am as many have stated going to go slow and see what works and I will be glued to these pages and posts.. You all be happy and safe.. Happy Riding
Your choice to go to a wide 180 on your '96 but there is a certain cool factor to just keeping the 130-140 rear size on a 20 year-old bike. I went to a 3.00 front on my '97 and am happy with it. Wouldn't go any bigger. Good luck.
BTW, Heartland makes a 180-200 conversion but permanent mods required.
