Looking for S&S E carb install tips
Hey All,
Im putting the 95 Softail under the wrench tomorrow. Installing an S&S E carb on the girl.
Anything I should look for, watch for?
Ill be running all stock, but the ThunderHeader exhaust.
Im a first timer with removing the manifold, and re install.
I picked up the E Carb from J&P
One thing I have a lot of experience with is tuning carbs. I do not intend this to sound snarky even though it might. But since you are asking for advice. In my opinion the stock Keihin carb is superior in every way to the S&S. Especially if you use Keihin jets and not a Dynojet or similar kit. You can get better fuel mileage, better throttle response, altitude adjustment and as much power with the stock carb. As far as install tips. Put some vasoline on the intake seals where they go into the flange and snug them down in an X pattern. If you dont have one of the special allen wrenches made for this purpose you might have to cut off an allen wrench to get to the intake bolts. Looking at the back of the intake on the left side make sure the gap ends up being the same on both sides between the intake flange and the head. If it is off you risk having an intake leak. It is hard to get them exact. The S&S carb will most likely be too rich out of the box and you will have to experiment with the jetting. If it is too rich your bike will not run as well as it could. Start with a 28-295 intermediate jet. a 70-72 main jet and 2 1/2 turns. When adjusting the throttle cables make sure the throttle blade is opening all the way but with no over travel. If I have forgotten something hopefully someone else will chime in.
Thanks for all the tips Martin! I actually have been doing lots of reading, and your reply confirms everything Ive read as far as the installation.
Ive already pulled the trigger on the S&S, but I guess this is my way to compare. worse case I go back to the stock carb. I dont mind playing in the garage, but do want a smooth runner.
All I did was follow the S&S instructions (to the word) provided when I converted from MM EFI on my '98. Out of the box jetting was perfect with my true duals, otherwise stock motor. I did have to readjust my idle mixture after a few miles, I didn't have the bike warmed up enough when I did the initial adjustment.
I have a Super E on my 02 Softail. It was already installed when I bought the bike 6 years ago and I haven't touched a thing on it since. It starts on the first crank whether hot or cold, I drop the choke in less than 5 seconds and it picks up a nice idle, rarely if ever stalls on the warm up. I guess the secret is getting it jetted/tuned correctly and the rest will fall in place. I've had a Super E on an FXR and an EVO Softail and have never had one issue with them.
Lakerat (07-30-2016)
Last edited by hdpearson13; 07-30-2016 at 12:46 PM. Reason: For some reason I thought your bike was a tc95 but same still pertain except you have better heads for the job.
Took a long time for me to get that bike the way it is and can't imagine starting over. The paint was done by a dear friend of mine....most likely his last project, so that is irreplaceable.
