Leaking air
This may sound trollish but if you can't figure out how to get the front wheel off the ground perhaps you need to let someone else do the job.
Also, your issue isn't "leaking air in the spokes", your issue is you have a leak in the tube.
Getting the wheel off the ground should be the easy part of the job.
(1) The OP hasn't said whether the leak is in the front or rear wheel.
(2) The OP hasn't specified whether this is a tube or "tubeless" spoked wheel.
As for getting the wheel off the ground; I stand by my assessment.
If the OP can't figure out a way to raise the wheel they probably should take the bike to a mechanic.
Dynaryder85
01-15-2012 04:23 PM
