2001 fatboy Stalling out
09-02-2016, 01:16 PM
I have an problem after the bike gets warmed up when coming to a stop and pulling in the clutch it idles down and stalls out it starts right back up I have replaced the speed and crank sensors it also is not throwing a code any ideas
09-02-2016, 01:55 PM
09-02-2016, 02:22 PM
09-02-2016, 02:57 PM
09-02-2016, 04:57 PM
+1. I would suspect a hole worn in your fuel line within the tank. Is the problem worse, better or the same on a full tank vs. a partially full tank?
09-02-2016, 09:23 PM
Hole in fuel line or IAC sensor. You'd think IAC sensor would throw a code, so I'd check fuel line first.
09-03-2016, 12:59 PM
It doesn't matter what fuel level
09-03-2016, 02:42 PM
Fuel delivery problems like those mentioned will give you more trouble under load, not at idle where less fuel is needed. What RPM is your idle set at? If you are trying to get the potato-potato sound it is too slow. It's a twinkie, not a shovel.
Dan
NJHarley66
04-03-2014 05:21 AM
hillbillyjim99
10-12-2009 12:23 PM
teamstersteward
06-21-2009 09:00 AM
Jim_McD
Exhaust System Topics
04-23-2008 02:19 PM
Lemond
04-12-2006 12:27 PM
