Any add on oil temp or pressure gauges?
I have the HD oil level and temperature combination unit in black, and happy with it.
http://www.harley-davidson.com/store...10-62700194--1
I thought our current EFI operated bikes had EITMS (Engine Idle Temperature Management System) also known as "rear cylinder cut off"...
At 70 deg. ambient temperature and the bike at normal operating temperature it only takes about 2 minutes sitting still at idle for the head temperature to climb enough to engage the EITMS. Anytime your bike is at operating temp and you sit at idle for 2 minutes or longer the EITMS should engage. On a windy day that may not be true because then the engine is getting some airflow even when sitting still, but under normal conditions the EITMS should engage. Additionally, if you're playing with the throttle, moving even slightly, do not have the clutch completely disengaged, or the idle rpm is above 1200 rpm, the EITMS will not engage.
Here are the parameters that activate the EITMS:
- Engine temp is > 287 deg
- Twist grip opening is at idle
- Vehicle speed is < 1 mph
- Engine speed is < 1200 rpm
- Engine temp falls below 275 deg
- Twist grip opening is > idle
- Vehicle speed exceeds 2 mph
- Engine speed exceeds 1350 rpm
- Clutch is released with vehicle in gear
Wow. All these expensive , real nice gauges are beyond cool. On the red bike I've got a cheap analog oil pressure block mounted gauge that replaces the oil screen acorn cap. That motor is more Shovel than Evo anyway, but it works and is accurate enough for me. On my TC88 Heritage, my oil tank mounted analog temp gauge is all HD and seems to work just fine. Old school stuff.
