What have I done!?
Old 11-30-2016, 04:36 PM
wideglideCVO's Avatar
wideglideCVO
wideglideCVO is offline
Received 1,380 Likes on 808 Posts
You will get more scratches on your chrome and probably only you notice it. Can't always look perfect.
Old 11-30-2016, 04:48 PM
chaselee's Avatar
chaselee
chaselee is offline
Yeah I know it just aggregates the **** out of me to do something like this.
Old 11-30-2016, 04:52 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 6,989 Likes on 2,814 Posts
Shoot whoever advised you. What I would have tried was rubbing gently with a cloth and some acetone. If that didn't work I'd have tried getting it off with some Easy Off oven cleaner on a rag and if that didn't work I'd use a small piece of #0000 steel wool with LOTS and LOTS of oil an very little elbow grease. But I'd put my money on the acetone or oven cleaner because it's worked for me several times over the years on the occasional airborne plastic bag.
Old 11-30-2016, 05:06 PM
chaselee's Avatar
chaselee
chaselee is offline
Hell I guess it's my fault, cause I scrubbed the hell out of it til it came off.
Old 11-30-2016, 06:07 PM
E8USMCRET's Avatar
E8USMCRET
E8USMCRET is offline
Received 20,250 Likes on 6,546 Posts
Pull the shield and have it rechromed locally or maybe find a new take off. You can always have them powder coated flat or satin black. It sucks to jack up your own **** but it's better than someone else doing it that won't confess or ***** out of it.
Don't feel bad, my Street Glide rolled out of gear down a friends driveway, $3,000 later I had a new paint job.
Old 11-30-2016, 08:16 PM
deadman77's Avatar
deadman77
deadman77 is offline
You polished off the chrome plating. Wish that was my biggest problem
Rakthi (12-07-2016)
Old 11-30-2016, 08:20 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,319 Likes on 3,267 Posts
You should be able to polish with a cotton wheel and rubbing compound
Old 11-30-2016, 08:36 PM
Prot's Avatar
Prot
Prot is offline
Received 14,115 Likes on 6,203 Posts
A new or slightly used heat shield should be able to be had for cheap.
Old 12-01-2016, 09:16 AM
Gaz B's Avatar
Gaz B
Gaz B is offline
That'll work a treat and no one will ever notice until you point it out to them.
When I cut my shields back the chrome peeled away on one of them but an hour or so of polishing (don't use anything too abrasive) will bring up the exposed nickel plate up nice and shiny.
Old 12-01-2016, 02:26 PM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
What I found best to remove crap from exhaust pipes is a plumbers torch and a fresh cotton rag. Heat it up and wipe it off.
Quick Reply: What have I done!?
