Inner primary cover question
I have a 2002 Night Train. The outer primary cover has the oval removable cover like a Dyna, is there a way to tell if the inner primary cover has the hole in it like the Dyna has so that you can feed the gear shift linkage through. I'm asking because I would like to mid controls on but if need to replace the inner primary cover I may forgo this mod for now.
Thanks for any input/idea's
Remove the outer primary and you should be able to see the boss in the casting.
https://www.hdforums.com/forum/softa...n-softail.html
Hope this helps and good luck with the project.
I removed the inner primary not only for drilling and inserting the new bush but also to be able to install the Dyna Mid controls linkage.
I used a drill press but it almost ended in disaster!
Mines a budget entry machine and unfortunately it suffers with a lot of chuck runout and drilled oversize and I couldn't use the new HD Bush.
With the inner and outer primary covers off the bike I bolted them back together and inserted a drill bit through the outer primary to correctly mark and pilot drill the inner cover.
newzealand (11-13-2021)
