Breakout Reach Issues
Thanks, I like them more than most I have seen.
Maybe I'm seeing it wrong but there looks to be a pretty big gap between the spacer and the top triple tree? I can see what appears to be the bushing cup washer, is that the way the Heartland spacer goes together?
Yeah, that gap is far to big! Those spacers are supposed to sit nearly flush with the trees, like the risers normally do.
I hate to be a party pooper, but WTF!!... They're not even the same diameter as the rest of the riser. Did Heartland loose their calipers, or are they that sloppy?
To each their own. I had spacers that were the same diameter as the base of the riser and I took them off because they look like ****. The step up in size made it flow better and not look like I just stuck a spacer in there.
Spacers might be machined at the exact same diameter of the riser base or slightly larger, it's just a matter of taste.
The riding position benefit of this cost-effective mod but in terms of look something better can be done.
I had some custom risers CNC machined from a local shop (Tecnicad) and pretty happy with the result.
Sent them stock risers as a sample for measures, I asked to add 1" length, have them slotted and chrome plated and that's it...
http://www.prototecnicad.it/en/negoz...-mod-line-art/
