2013 SLIM front turn signals..
Old 02-07-2017, 05:28 PM
AlexJamess's Avatar
AlexJamess
AlexJamess is offline
5th Gear
Default 2013 SLIM front turn signals..
New to the softail world here so bear with me...
Removed the turn signal from the handle bar and as I looked a bit closer I see the wire goes into the switch housing and doesn't come out. Internal bar wiring I see.
So my question is...
Do i need to take apart the housing and cut the wires to relocate them to use a fork mounted turn signal?
thanks in advance
Old 02-07-2017, 06:14 PM
Bamjoop's Avatar
Bamjoop
Bamjoop is offline
thanks in advance
Go to the other end of the wires where they come out of the bars and have a plug end. If you do some research online, you can easily disassemble the plugs and then pull the wires out through the top end leaving them connected to the turn signal. Then just reassemble the plugs. That is if you want to keep everything intact.
AlexJamess (02-13-2017)
Old 12-16-2020, 02:43 PM
Valdemar's Avatar
Valdemar
Valdemar is offline
look better in the handlebar.
JefFLH
07-23-2017 03:08 PM
Valdemar
12-19-2014 01:59 PM
TXJames
12-04-2013 11:28 PM
Essentialbill
02-16-2013 01:26 PM
lhgdale
01-06-2010 01:29 PM
Quick Reply: 2013 SLIM front turn signals..
