chrome oil line leak 2017 heritage
This is what you are after:
those style of connectors are common and reliable as long as the fitting was installed correctly with lubrication. the dealer ship may have pushed the hose in with out lubing it up and it tore/pinched the seal inside of it. you may have some excess lube pushing its way out, or the seal is damaged and it is seeping. i would clean it and then ride it to see if it has stopped. if it continues take it back to the dealership.
UppercaseJC (03-23-2017)
It will stop my brand new Slim did the same thing right from the dealer.After 500 miles it was dry. Over lubed 0-rings seal is what it is.I am still waiting for the cylinder base to stop sweating on front and rear cylinder left side.I have seen them on the showroom like this.
UppercaseJC (03-25-2017)
Save learning for when you are out of warranty. Screw it up, and you own it.
Huh?? What'd you say? 10 pts for best avatar.
