Fat Boy S Cruise Control Intermittently Working
Old 03-26-2017, 06:48 PM
uklauren's Avatar
uklauren
uklauren is offline
Florida Crew Moderator
Received 3,389 Likes on 1,560 Posts
Default Fat Boy S Cruise Control Intermittently Working
The red light on my dash has come on twice in the past month for no reason that I could figure out until today when I put the cruise control on and the red dot lit up at the same time and my cruise control would not engage. After a few minutes the little red dot disappeared and cruise was working. However, I didn't trust it and turned it off again.
How I hate electrical gremlins they always seem to follow me from bike to bike. Another trip to the dealer coming up for warranty work.
Old 03-26-2017, 07:30 PM
UHDhog's Avatar
UHDhog
UHDhog is offline
I bet one of your brake switches is sticking. My front brake lever doesn't always extend all the way forward, just enough to keep the brake switch on. If the brakes stay on at highway speeds, the red light will come on after a while until you push the lever forward so the bike thinks you are not applying brakes.
I would look at that. If the issue happens again, push your brake lever forward and see if the light goes out and cruise works again. If so, then it might still be covered under warranty.
Good luck
Old 03-26-2017, 07:48 PM
uklauren's Avatar
uklauren
uklauren is offline
It should all be covered under warranty, I'll let the dealer look at it.
Old 03-27-2017, 10:30 AM
Johan96's Avatar
Johan96
Johan96 is offline
Keep us updated. Have had the same with mine. Good luck��
Old 03-27-2017, 07:15 PM
uklauren's Avatar
uklauren
uklauren is offline
Do you remember what the dealership fix was?
Old 03-28-2017, 04:07 AM
Johan96's Avatar
Johan96
Johan96 is offline
The mechanic said that I must contact them if it happens again. The bike went for winterisation and still is.
ZBear
18
06-30-2017 03:30 PM
vdude
05-17-2017 08:33 AM
toecat2000
08-05-2016 07:47 AM
Radalack17
08-19-2012 02:44 PM
roger scarcliff
11-09-2010 01:05 PM
Quick Reply: Fat Boy S Cruise Control Intermittently Working
