Oil drain plug??
Oil drain plug??
Does my 92 EVO Fatboy have anoil drain plug in the bottom of the engine crankcase? Or do I just drain the oil tank and change the filter? I have been doing it that way for a while but never seem to get 3 quarts out. Is that normal? I looked for something that looked like a drain plug but never saw anything that looked like one.
RE: Oil drain plug??
Just drain the tank and replace the filter, start the engine and let it idle a couple minutes, check the oil and add as needed. The normal refill is about 3 - 3 1/2 qts. The book capacity is for a new bike that has never had oil in it. The difference is because of oil filling all the oil lines etc.
If you want to get all of the oil out, go to www.roguechopper.com and check out their scavenger system. Have one for my softail and I get almost a quart out of old oil out of the engine.
rogerbush
12-05-2011 11:13 PM
