Vance and Hines Fuel Paks...????
I just bought my 07 Softtail Custom 3 weeks ago...and have a question about the new Vance and Hines fuel paks.
I bought the V and H Big Shots Staggered and they recommend their
new fuel paks to match up with the pipes...
since they cost less than half what Harley sells...I'm thinking about buying the V and H ...they are suppose to be a better set up...but then I don't want to install anything that would mess up my warranty...
anyone else using the Vance and Hines fuel paks..????
RE: Vance and Hines Fuel Paks...????
I installed V&H big shot staggerds,fuel pak and stage 1 on my 07 deuce. Like DaveJ said check the posts.....some get alot of popping between shifts and say that changing mode 23 setting from 16 to 50 fixes that. I do get a pop out the exhaust between shifts ...but only a couple times a week. For me the BSS were too tinny at idle and I just installed quiet baffles which make a nice difference at idle....also added some lower end torque. ...still loud on accell.
Go Power Commander.....
It's so easy it's like making a peanut butter and jelly sandwich....
I just installed V&H BS Longs, a stage 1 and a power commander. Installed the accelerator pump utility and the map accordingly. No back fires... no popping... no disatisfied customer. I luv the PC.
I would go V&H also. If you were to purchase the SERP you would only be able to choose Harley pipes, air intake kit or anything else.
So since you are going with V&H pipes, go with the power commander or fuel pak. But on another side. I have heard of a few guys whose harley computers burned out and harley would go good for them because they had installed something other than harley on it
Vance and Hines tech's are lousy to deal with. I've talked to three different techs and I got three different answers to what program to use to dial in the Fuel-Pak for my bike and application. I was finally told, after much discussion that they don't have a map for my application and were unable to help me. I gave up and went with the Power Commander III. Been happy ever since. Maybe if they ever get thier act together, they'll have a great product.
ORIGINAL: Bowtieman31
PCIII for me from FuelMoto. Gave them my set up and sent me the PC with the correct map. Plugged it in and no problems. The simpler the better for me. I have no experience with the Fuelpak, but what I've read on this forum, I don't want any. They do make great exhaust systems. That I do have.
