O2 Sensor Bypass
Old 08-13-2007, 02:47 PM
Live2Ride's Avatar
Live2Ride
Live2Ride is offline
Banned Camp
Default O2 Sensor Bypass
I was looking at exhausts and in order to run some of them on a fuel injected bike, you have to get an O2 Sensor bypass. Which do you guys recommend, and does bypassing the O2 sensors have any negative affects on the bike? Forgive me if these are dumb questions. I don't know much about FI bikes. My Deuce is carb'd and I'm thinking about possibly gettin' a new bike, which would be FI. Thanks for your help.
Old 08-13-2007, 03:14 PM
bdavis385's Avatar
bdavis385
bdavis385 is offline
Default RE: O2 Sensor Bypass
For starters you might want to go to www.nightriders.com. They have a good articles in EFI.
Old 08-13-2007, 03:24 PM
PoorBoy's Avatar
PoorBoy
PoorBoy is offline
You'd be removing one of the feedback loops that the ECM considers when deciding FI commands to the injectors. Like you've said, you need some "loop-back connector ends" that go on the end of the cables when you remove the O2 sensors.
There's a pretty good write-up at V-Twin Cafe about using wideband O2 sensors, and their role in general: http://www.nightrider.com/biketech/h...o2_upgrade.htm
There are both flavors of fuel commanders (speaking generically) that can deal with or ignor the presense of the O2 sensors. The O2 sensors are a great source of info for the ECU to decide about idle mixtures going to the injectors.
In all cases, don't do an exhaust (minus the O2 sensors) that hasn't been accounted for by one of those fuel commanders. The bike would run horrible without somehow telling to ECU to ignore an O2 sensor input.
P.S. I am not affilliated in any way to V-Twin Cafe, I just like reading their research.
Old 08-13-2007, 03:58 PM
Live2Ride's Avatar
Live2Ride
Banned Camp
Thanks for the info and links guys. I appreciate it.
Old 08-16-2007, 11:44 AM
dmac1968's Avatar
dmac1968
dmac1968 is offline
Mine runs BETTER since putting the eliminators on and switching to PCIII. In Aus and Europe we have FOUR eliminators to fit. The extra 2 are the airbox and active exhaust eliminators.
DeanO
ORIGINAL: Live2Ride
Old 10-18-2009, 09:50 PM
dmac1968's Avatar
dmac1968
dmac1968 is offline
Default active exhaust bypass eliminator kit harley
If you are looking for the eliminator kit, I know that www.cheapbikeparts.com.au has them in stock.... You will need them if fitting a new exhaust and / or air filter to your bike to stop the engine warning light from coming on...
Most of the Vance and Hines exhaust kits make no mention of the active exhaust module which you must REMOVE when fitting an aftermarket exhaust such as Vance and Hines etc . After you remove the big module from underneath the frame and unplug it , one of the 2 plugs supplied in the kit is plugged into where the module came off the bike and the engine warning light will disappear.
PumpinIron
10-01-2021 07:07 AM
johnl111
06-06-2016 10:46 AM
JockWhisky
02-07-2013 11:14 AM
nevil
06-05-2010 03:55 PM
car5car
11
10-23-2009 04:57 PM
Quick Reply: O2 Sensor Bypass
