Pros & Cons of lowering
RE: Pros & Cons of lowering
My Dad had a Fatboy that was lowered and he would scrape the floor boards all the time turning into parking lots and stuff. However, he just changed out the boards and with forward controls and never had any other problems. None of that matters, though, because the bike in question isa Nightrain. So really the responses that should be looked at should be the ones regarding the FX style frame. The FLs obviously handle differently when lowered.
Couldn't help but get a giggle out of this! We went thru a lot of trouble on the old pans and knucks to get that dam primary up high enough to avoid grounding it on every left turn. Other that extending forks, 18" tires, I guy went to the extent of cutting and flipping the rear frame legs to add 2" height at the rear. Looked kind of funny but he was the only one who could actually drag his pegs.
Can see it for those with short inseams, but the modern cast aluminum primaries don't take to bashing on the concrete too well.
I have an 04 Train and had a 1.5" cheapy lowering kit on it, Not a bad ride but did sacrifice a bit when riding 2up. The nightrain never had the scraping issues because of the forward controls and when I put the 2into1 pipe on, that took away any thought of scraping on a turn.
ORIGINAL: spdball
If anyone doesn't experience this, I'd suggest you read this whole thread (link below)and look at the pics. Fascinating reading.
I'd never lower a Harley.
https://www.hdforums.com/m_2025383/mpage_1/key_/tm.htm
Wanna watch someone scrape the bottom of a Goldwing in good riding technique? Here:
http://www.goldangels.com/videos/Obs...bsticalmpg.htm
I know Kuryakyn just put out a new set of adjustables for the 89-99 & 00-07 softails, but don'tknow much about them. They are in the 07 catalog.
http://www.kuryakyn.com/products.asp...ey&ci=3530[sm=signs003.gif]
ORIGINAL: spdball
When I had My 2 into 2 staggered pipes on, I would occationally scrape, But since the 2into1 pipe, if I leaned over far enough to scrape I'd have bigger problems than a scratched pipe.
