Check Engine light?
Check Engine light?
Ok, I have a check engine light question. I have a 2005 FLSTF-I that I just installed Vance & Hines Straight Shots and a Fuelpak. Everything runs fine but if I open up the throttle all the way, the check engine light comes on and stays on until I turn the motor off. When I restart, the check engine light comes on for about 4 seconds, then goes off. As long as I’m easy on the throttle, the light does not come on, if I open the throttle fully, the light comes back on. Any help / explanation of this would be a big help.
Thanks.
Thanks.
RE: Check Engine light?
Im having the same problem with my 07 deluxe, did you reinstall the O2 sensors, im thinking that the engine is trying to monitor the afr and its sending a red flag cause there is nothing at the other end. If i find anything out i'll let you know. Please do the same man
There are detailed instructions on this site somewhere
But a quick shot is
switch the RUNswitch on
While holding the odometer button in
Cycle your Key switch on to off
wait to see the speedo needle sweep
Should see DIAG
Then press the odometer button back
should see PSST
Hit the odometer again for a code
Again check the site for a more detailed description
Its easier to do it then to type about doin it
But a quick shot is
Should see DIAG
should see PSST
Here ya go for the codes...
Check it out!
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM
Check it out!
SP = speedometer
T = tachometer
P0501 VSS Low Carb
P0501 VSS Low EFI
P0603 ECM EEPROM
Did 05's have O2 sensors? I though only the 07's and up have them.
If you just installed a new high flow intake and didn't get the ECM updated with at least a stage 1 download map I suggest you take it off, FAST. The bike is going to run very lean with its original map and higher flowing intake and exhaust. Its going to start frying things inside and its quite probably the reason your getting that check engine light.
To be sure your going to have to read out the codes, but given the info you gave us here I have to believe the new intake is the cause of your problems.The ECM is probably freaking out athigh throttle settings because the new intake is allowinghighermanifold pressure levels than the stock map can handle properly.
ORIGINAL: Citoriplus
To be sure your going to have to read out the codes, but given the info you gave us here I have to believe the new intake is the cause of your problems. The ECM is probably freaking out athigh throttle settings because the new intake is allowing higher manifold pressure levels than the stock map can handle properly.
