Need help with Fuel Pak
Hello all,
I installed a K&N air kit, vance and hines fish tail slip ons and of course the fuel pak. I used the values given by Vance and Hines. The bike runs pretty good but has a tendacy to cut outand or act like it is stalling out. I did see flame shoot out of the throttle side muffler on decel.
The bike is an 05 springer classic. Was wondering if anyone had an idea or value changes without having to dyno.
Thanks for any help.
RE: Need help with Fuel Pak
I'm going with the exact same setup shortly. Right now I just have the Fishtails on, no air filter or FuelPac.
I do have both set of baffels and the biker runs "sort of" better with the quite baffels, it does backfire a bit with the regular ones.
One thing I did notice on the FuelPak site was different settings for each set of baffels so check for that first and make sure you are using the correct settings.
I will be curious how it works out for you as I'm right behind ya!!
