brake and shift lever replacements
Greetings:
Newbie here (07 softail custom)
I would like to change the plain jane rubber on brake and shift lever.
It appears based on those items listed in catalog that a different lever will also be required as the current pads appear to be "stuck" on with glue or similar.
Would someone confirm what I already fear?
Thanks in advance
Thanks in advance
RE: brake and shift lever replacements
You can "slide" off the rubber pad on the brake lever. Just take a screwdriver and pry it from the foot side of the pad. The new pad will cover up any scratches you do on the lever as long as its under where the existing pad is now.
The shifter peg unscrews from the lever. I had to cut the rubber off with a utility knife and the use a pair of visegrips to unscrew it. No big deal though.
