WTK: Is the HD Wide Tire Kit Worth It?
Old 12-06-2005, 02:20 AM
ultravista's Avatar
ultravista
ultravista is offline
Default WTK: Is the HD Wide Tire Kit Worth It?
My 2001 Night Train has a pretty skinny 130 rear tire. I'd like to go bigger and see that Harley sells an entire kit (43685-00A) that moves you from a 130 to a 150. Kit is complete with all hardware.
The question is ... do I need this kit to put a 150 on the stock 2001 FXSTBI? Is it a waste of $$ or ? What is an average cost of a $150 tire anyway?
Old 12-06-2005, 10:53 AM
JamieWG's Avatar
JamieWG
JamieWG is offline
Default RE: WTK: Is the HD Wide Tire Kit Worth It?
There are a couple of ways you can do it... you can piece out the parts from a Duece, then you get some added chrome. You can also swap out the pulleys and drivebelt. MegaHDman recently posted some good info on this swap. If you can't find it by searching, send him a PM. His way of doing it was slick.
Old 12-07-2005, 08:23 PM
ultravista's Avatar
ultravista
I was asking as there are a few on ebay in the $250 range, complete in the box from a HD dealer. It seems like an inexpensive and non destructive way to get a little more tire.
Old 12-07-2005, 08:45 PM
MegaHDman's Avatar
MegaHDman
MegaHDman is offline
Im not familiar with the kits or what they come with other than the tire. Post a link to the kit. I assume it comes with some spacers, and maybe new updated struct brackets to allow safe clearance inside the fender well for the 150.
Old 12-08-2005, 12:46 AM
JamieWG's Avatar
JamieWG
JamieWG is offline
I've got a friend with a 2002 FXST who priced the HD wide tire kit. He ended up saving money by purchasing stock parts off the 2002 Duece, and ended up with the same sized tire offered in the kit (which I think is a 150). He was real happy because he got the parts for less money, plus the caliper off the Duece was chrome. I can't recall all the details cause this happened about 3 years ago... and I don't know if the 2001 NT is the same as a 2002 FXST. Just trying to help by offering an idea you might want to look into..
Old 12-14-2005, 04:14 PM
ultravista's Avatar
ultravista
Here's the link, sorry for the delay.
HD Wide Tire Kit (Softail)
It comes with everything needed to go from a 130 to a 150. As I said before, the kits can be found on ebay for $200-$250 from a dealer.
Old 12-14-2005, 05:32 PM
berryCR's Avatar
berryCR
berryCR is offline
Honestly I quite do not understand what they offer.
Right now I have on my FXST 2000 130tire mounted on stock rim 16x3.0.
There is 20mm (3/4") gap between tire and belt or guard.
If I put there 150mm tire (which is the maximum tire I can put on stock 16x3.0), it means that it will be (150-130)/2=10mm wider on both sides, which means that the gap between tire and belt will be 20-10=10mm which is still a lot. So I do not see any need to by this whole kit.
I think Dunlop tire is the only thing you need, which is for about $110 on ebay (including free shipping) See Dunlop 16x150
Old 01-18-2006, 01:35 AM
ultravista's Avatar
ultravista
berryCR, did you ever go the 150 route?
Old 01-18-2006, 12:26 PM
Screamer's Avatar
Screamer
Screamer is offline
130 to a 150 seems like a small gain. You would think Harley would offer a 200 kit, now that they have that on some of their new bikes.
Old 01-18-2006, 11:51 PM
8 UP's Avatar
8 UP
8 UP is offline
You can go to A 160 on 04's and up.
As for the 200, Harley changed frames ( I thank they are using the Deuce frame) in 06, as well as a smaller belt (13/16").
Quick Reply: WTK: Is the HD Wide Tire Kit Worth It?
