Running lights, spotlights, auxillary lights
Hey guys first time posting here. The sight is great. I'm looking for some spotlights that are a little dif than OEM. I know headwinds make a nice set. Just wondering if anyone has found others. I've been looking a while. Many beautiful bikes in the pic area. Great minds are here. Help please. Thanks
RE: Running lights, spotlights, auxillary lights
Change your headlight.
http://www.eurocomponentsusa.com/lig...sub=headlights
Modify some rice bike stuff to fit your bike.
http://www.customdynamics.com/barons..._light_bar.htm
http://www.customdynamics.com/driving_light_bar.htm
http://www.customdynamics.com/haloge...ing_lights.htm
That would give you some choices.
I used the Kuryakyn (large) HALOGEN Silver Bullets. Running 75 watt 10degree spots, attached to forks under triple tree.
http://www.kuryakyn.com/products.asp...ey&ci=2611
[IMG]local://upfiles/6335/08C4A0E49C844877A3D19403F178520A.jpg[/IMG]
ORIGINAL: agapsdiver
I used the Kuryakyn HALOGEN Silver Bullets. Running 75 watt 10degree spots, attached to forks under triple tree.
Its getting close to the dumb deer mating season around here and the stupid things are starting to get restless running across the roads at night. I would like to see about getting more/better lighting in front to avoid hitting one if its at all possible.
ORIGINAL: Citoriplus
Which model (large or small) do you have on your bike an how well do they work at night?
I purchased the large
_2319 // $99.99 _ORDER NOW
Large Halogen Silver Bullets (pr)
( note that I changed part # from my orig. post)
http://www.kuryakyn.com/documents/in...-22HD-0604.pdf
I believe they came with 35 watt bulbs...switched to 75 watt spot..
The light is amazing....really lights up your world..
http://www.servicelighting.com/catal...m?prod=AL04457
ps..if you look closely at my pic... you'll see deer alerts attached....central Tx. has it's share of deer....
Thanks a lot.
I am looking for more light andhave been seriously thinking of going with thenew double headlight assemblies off the new 08 Fatbob.
06Deuce has it on his bike and having a secondheadlight out front will definatly getmore light out there.
Your solution to the lighting problem is at least gives me another and less expensive option.
Even if it doesn't have the same"Custom" look a newheadlight setup would.
My bike isn't the cleanest setup but it is certainly bright with each pai of light on a seperate switch. The headlight is HID (put in an Adjure housing), H4 bulbs in a stock HD passing lamp set up. (You could put smaller aftermarket lamp(more proportional with teh headlight)and Trailblazers put on the forks. http://www.batteryspace.com/index.as...;Category=1043
[IMG]local://upfiles/19735/46946049C69D40A496F068D0ED33AF4F.jpg[/IMG]
EE_Bean_Goh
03-07-2011 08:13 PM
