Heritage softail solo?
I have a 2006 Heritage Softail with the passenger pillion. When the pillion is removed, there is a plastic "sticker" that protects the fender. What do most of you do when you ride solo without the pillion. Will it harm the paint if the protective sticker is removed and what about the 2 bolts for the pillion. How can a clean look be achieved?
Thanks.
Thanks.
RE: Heritage softail solo?
Get a rubber plug (made by harley) with the bar and shield on it for the holes. Don't know about the fender getting damaged or not, but you can take a hair dryer to the sticker and peel it and use wd40 or goo gone to remove the rest of the glue...I have a double seat obviously.
ORIGINAL: anubisss
It's a bit of a pain to cut out and put on the fender if you're going to be removing and putting back the passenger pillion often, but if it's just something you do now and then, the stuff is clear and does a pretty good job of protecting the fender.
I use the MustangFender bib too. It looks great and it's inexpensive.
http://www.mustangseats.com/softail/softail.shtml#i
