Battery issue with 07 Heritage
As winter hit I parked my bikes inside a heated shop for winter service. I serviced the first one and did some modifications to it as well. It took about 30 days by the time the chrome shop and backordered parts were done. I took it off the lift and went to put my 07 Heritage on. I found the battery dead. This bike has a little over 2000 miles on it and nothing was left on. I would think that the battery should hold up for 30 days. Is this common or do you think I have a problem? I've pulled the battery out and recharged it. It seems to be a good one. One of the service items on my list was to install a tender cord however if I've got some draining problem I don't want to just cover the problem up with the tender. Any thoughts?
[IMG]local://upfiles/47469/DB406738762042148AE8869244A2CD0B.jpg[/IMG]
RE: Battery issue with 07 Heritage
I always use a battery tender after each ride. As soon as the bike cools it hook it up. I purchased mine from Summit Racing and it is a Autometer brand. Any good brand will do. My FatBoy came with a battery tender hookup already installed.
If not sure of the battery do a multimeter test to see the voltage reading when engine not on. Then do it again with engine running. If the static reading is below 11.5 the battery is toast. It should read 12 or slightly higher. Then when running it will register higher still. Make sure ignition switch is turned off when parking the bike to avoid current draw.
[IMG]local://upfiles/49300/D53EF89DEFB244F3B0D1726E9065DCF2.jpg[/IMG]
Vilrandir
Electrical/Lighting/Alarm
08-13-2015 04:32 PM
