07 Heritage/Easy Brackets questions
Read through all the posts referring to the quick detach options for bags. Looks like Easy Brackets are the best tradeoff for me but I havecouple questions for you guys that have them:
1) Will Easy Bracketsinterfere withchanging the stock rear turn signal bar?
2)Do Easy Brackets handle the lower support bar (near footpegs) on the stock bags?
RE: 07 Heritage/Easy Brackets quesions
I had them on another bike, so I'll be cautious in the answer. The Easy Brackets will not need the lower support bar. They are bolted to the bag and have a decent sized metal plate that hold them in place.
Long and short of it is that your question will depend on the year and model of your bike. Take a look at the Easy Brackets website for more information about how they mount ...
http://www.easybrackets.com
Chances are you'll need the HRT-R3 or HRT-R3DB. When I mounted mine on an earlier bike I bought them from Chilhowee Leather (http://www.chilhowee.net) with a new set of bags. Chil was pretty good at answering emails and I got decent phone service when I had a question about mounting. The system is basically designed to replace stock parts, so there is usually not a lot of problem with the mounting. You will need to drill holes in your bags for the mounting screws, though, but it's an easy job.
I had Easy Brackets on my 06 Heritage. They work fine, but don't use any lower bracket. The stock bracket is not used. I think they could use a lower bracket and thought about fabricating one, as the bags kind of move in and out at the bottom. They are a good product and easy to use. I took mine off, I didn't like the gap between the bags and the fender which was about
11/2" or so, and the looseness of the bags at the bottom. They are real handy when you travel, you can just take them off and put them in your room, no need to unpack the bags each night.
ORIGINAL: Mikester48
