data cable for thunder-max
I just installed the thunder-max, new pipes and a high flow air cleaner, now everything is great except I can't link my ecm to my laptop because the end that plugs into my computer is different. Does anyone where I can find an adapter or even a whole new different cable? I'm in Sanford, FL right now and have less than 2 weeks left before I have to go back to Fort Drum, NY and really would like to start riding again ASAP.
RE: data cable for thunder-max
The end on the cable is a serial port connection.
They do make a cable that uses USB connections if you don't have a serial port.
The part number is 372-000 from Zippers but you can get a USB to RS232 adapter from places like Comp USA.
http://www.thunder-max.com/Support/I...g%20Manual.pdf
Page 5...
Good Luck
Page 5...
Good Luck
This is the one I got.
http://cgi.ebay.com/USB-2-0-to-9pin-...QQcmdZViewItem
It works great with my TMax and it is cheap.
If your short of time CompUSA stocks an adaptor cable that should work.
I believe that you can evencheck the local store stock for it.
Here's the link to it.
http://www.compusa.com/products/prod..._code=50195798
Good Luck at Ft. Drum, I "visit" there every so often to fix the computers systems in the Guthrie Medical Clinic andit gets COLD up there this time of year. Thedeer can also be a real pain in the butt. So be very careful to keep an eye out for them if your riding or driving anything smaller than an armor plated Hummer.
Bobbed Out
01-29-2010 05:58 AM
