Shifter is sticking, not sure why
Well I had some nice weather today so I took the Fatty for a ride around town. About 1 hour into my ride I noticed that when I shift (heel/toe) the shifter wouldn't spring back into place. I actually had to nuge it backup in placewith my foot and then step back down to shift. PITA, so I came home to take a look. I looked back at the other side of the linkage and everything seems fine. When I was looking a little more closely at the pin I noted that there is no space at all around that black washer. It's pretty tight...im wondering if itisn't too tight. When I tried to take an allen wrench to the dogone shifter it is on so tight that I felt like I was going to break my wrench(need a good set). I tried to get some penetrating oil in there around the washer and at the back side of the pin...and tried to work it around a bid. I guess my question is - has anyone else had this problem? Is that washer fiberous? Is it possible that It would swell? What else could this be?
Im sure no wrench so I was just going with the common sense approach...only thing is I'm all out of common sense [8D]
Thanks in advance for any help you guys can offer!
JU
JU
RE: Shifter is sticking, not sure why
I had the same problem last week. I didn't know what was wrong and started making plans to bring it in to my dealer. But before I did, not wanting to look like an idiot, I sprayed a little WD40 and the two front pivot points at the linkage connections. After and little up and down motion, back to new. Try this and see if it clears up your linkage. Good luck and post back if it helps.
The shaft that connects the foot lever to the front linkage arm has rusted. You'll need to take it apart, sand the shaft back smooth, clean the plastic bushings, lube with some grease, and reassemble. This can be checked by taking the shift linkage loose from front linkage arm, if foot lever is tight, then the above solution will fix your problem. If it's tight at the lever at the transmition, oh-no!!!
[IMG]local://upfiles/49112/7CC5EE1C0C3440978BF0920219C80D9E.jpg[/IMG]
[IMG]local://upfiles/49112/5FD8BDC6F47049A2B8614DD92631ABE1.jpg[/IMG]
Mine did the same thing thing. a little liquid wrench and cleaning solved the problem. At the same time I checked the tranny fluid. I had ridden ina heavyrain, last summer, for a couple of hours.Water had got in the vent tube and there was water in the tranny fluid. I changed it to syn 3 no more problems. I really think the shifter sticking was it need to be cleaned and oiled.
ORIGINAL: I CUT 1
The shaft that connects the foot lever to the front linkage arm has rusted. You'll need to take it apart, sand the shaft back smooth, clean the plastic bushings, lube with some grease, and reassemble. This can be checked by taking the shift linkage loose from front linkage arm, if foot lever is tight, then the above solution will fix your problem. If it's tight at the lever at the transmission, oh-no!!!
This is very common.
Seems that the shaft doesn't get enough anti-seize.
As mentioned before, pull the the levers off, sand the shaft smooth, clean the inside out of the bushing, and coat in lots of anti-seize.
Figure on this being about a yearly task especially if you ride in the rain.
My first time, it even had packing celophane wrapped up in there.
