Another Battery Tender Question
When I connect the negative clip, do I attach it to the negative battery post or on the frame? If so, will the same place the negative cable attaches to the frame work? I also have the harness that stays on the bike (just not installed yet). When I install the harness with the ring terminals, do I install the negative ring terminal on the bolt connected to the battery itself, or the one connected to the frame?
thanks
thanks
RE: Another Battery Tender Question
Its always better to attach anything like that to the battery terminals.
That way there is no possiblity of a bad connection to another part causing an increased loading on the smart charger.
Smart chargers only put out a very small amount of current and any loss through increased resistance could easilyoverload it. If you were using one of those giant rollup fast chargers, it wouldn't matter so much because they have power to spare. Likely more than the averagebikes little battery can handle for very long.
The instructions for my battery tender tell you to attach the negative to the vehicle chassis. Of course I didn't read the instructions so mine is connected to the -terminal. If I find some good reason to move it I will but for now it's staying there.
I'm thinking the reason for the frame mounting is to reduce possible sparking at the battery during the connection or if it ever gets loose.
People read instructions? Wow, that's news to me!! Seriously though, I put my quick-connect harness right on the battery post. Like Citoriplus said, it best matches what the tender does. If I'm jumping a car, or using a hoss of acharger, I usually find a frame ground to use for the negative. This reminds me, I haven't ridden my bike since Thanksgiving Day. My wife and kids (plus freezing cold weather and my day job) are helping make sure my battery tender spends more time with my bike than I get to!
Mike
Mike
The reason they tell you to attach the negative clamp to the frame (not the neg terminal on the battery) is so that there is no chance of igniting any hydrogen gas that may be built up near the battery. Now the chances of this are pretty slim, but when applying jumper cables or a charger that is pluged in already a spark can be produced (like a spark plug) and kaboom.... but the chances are slip. As for the quick connect cable, just attach is to the pos and neg terminals, plug in the tender to the tail and then plug into the wall. Youll never have a problem.
Chris
Chris
