Fuel Gauge removal?
Old 01-27-2008, 09:24 AM
jtmurph00's Avatar
jtmurph00
jtmurph00 is offline
Default Fuel Gauge removal?
Ok, I want to replace the fuel gauge on my 07 Night Train with a plain flush mount cap. I know the gauge just pops out but, are there any threads in that hole, will a left hand thread cap fit in there or does it have to be something that will pop back in? Im not at home so I can't look at the tank to see. thanks
josh
Old 01-27-2008, 09:37 AM
Arvis's Avatar
Arvis
Arvis is offline
Default RE: Fuel Gauge removal?
No thread there. Simple cap would not fit, hole is much wider. Also you will have to lift the tank to disconnect the cable and remove the plug from it.
Old 01-27-2008, 12:23 PM
jtmurph00's Avatar
jtmurph00
Yeah, I knew I was gonna hafta pull the tank to get it off and as bad as I am with a wrench it will probably wind up being a major, several dayordeal. But those damn factory caps are so ugly Im willing to risk it. Just gotta find something to replace the gauge with now.
Old 01-27-2008, 03:10 PM
niczumbo's Avatar
niczumbo
niczumbo is offline
i just put the flush mounts on my standard 2 weeks ago.the gauge pops st8 out and its easier if you jack up the bike to get to the wire connection under the tank you also need to remove the wires from the connector block ,,,or you must cut them to pull the wires threw the tank [sm=confused06.gif]
Old 01-27-2008, 09:04 PM
EdwardK's Avatar
EdwardK
EdwardK is offline
You shouldn't have to pull the tank. The wires from the fuel gauge plug in under the tank. They come out directly under the fuel gauge. If you feel your way you should be able to pull them out far enough from under the tank and get to the plug.
As niczumbo says, the plug won't feed up through the tank. You'll either have to cut themor you'll need a special tool to remove the wires from the plug. The end of the wires are crimped into a pin that locks into the plug. If you have the tool you can remove the wires from the plug and then reinstall into the plug if you ever wanted to reuse your old fuel gauge.
Old 01-28-2008, 05:45 AM
Stevenacnj's Avatar
Stevenacnj
Stevenacnj is offline
The low profile gas gauge install is pretty easy. Toughest part really is getting the wires in correctly on the new plug.
Just disconnect the old plug (located under the tank) and cut it off. If you leave enough wire can always solder them back together for future use.
Old 01-29-2008, 12:30 AM
Arvis's Avatar
Arvis
Arvis is offline
I guess getting pins out is way easier than soldering the wires
Old 01-29-2008, 01:57 AM
jtmurph00's Avatar
jtmurph00
Thanks for all the advice. I dont think gettin the gauge out and off should be that much of a problem. The real issue will be figuring out what the hell to replace it with.
Old 01-29-2008, 03:04 AM
Yogi's Avatar
Yogi
Yogi is offline
I see from your first post that you want plain flush - go HD plain flush with LED indicator - looks real nice.
Old 01-29-2008, 03:35 AM
Arvis's Avatar
Arvis
Arvis is offline
Did you consider KURYAKYN gas cap and fuel gauge ?
Quick Reply: Fuel Gauge removal?
