scratches on fatboy rim
Old 02-04-2008, 04:38 PM
Pat C's Avatar
Pat C
Pat C is offline
Default scratches on fatboy rim
Can scratches on an 07 fatboy's rim be removed? I must of scrathed them whem removing rear tire.
[IMG]local://upfiles/45014/A59EF75AF4644E1198E4B9233FBD011B.jpg[/IMG]
Old 02-04-2008, 06:02 PM
peterson24's Avatar
peterson24
peterson24 is offline
Default RE: scratches on fatboy rim
I'm in the same boat, scratched it with the brake caliper taking off the rear wheel. Pain the butt also.
Old 02-04-2008, 06:21 PM
anubisss's Avatar
anubisss
anubisss is offline
Me too. IF you want to sand it down and polsih the caluminum it can be. I just forgot about it...
Old 02-04-2008, 07:02 PM
DrawDown's Avatar
DrawDown
DrawDown is offline
Yea, i think if you took a fine grit sand paper and went the direction of the machining "cuts" in the metal, it should look ok. I had a set of wheels on a camaro that had the lips machined like our fatboy wheels. They had some scratches on them and the sand paper did the trick. Might be worth a try.
Old 02-05-2008, 05:48 AM
Stevenacnj's Avatar
Stevenacnj
Stevenacnj is offline
Small scratches are strange & sometimes appear out of no where. I did some polishing last Sunday and noticed some new ones. I am in the camp of just leaving them alone. They will drive you nuts otherwise.
marecycling
05-22-2008 06:39 PM
abcd9906
10-25-2007 09:03 PM
nuklhd
10-04-2007 11:38 AM
93HD
04-14-2006 12:07 PM
rick
04-05-2006 02:36 PM
Quick Reply: scratches on fatboy rim
