Extended forward controls
RE: Extended forward controls
i am 6'3 and i put on the arlen ness 3 in exctions. and i love then. it really helped to inprove the ride. the pegs mover oue 3 in and they did not move down one bit. i belive that the are around $156.00 for the kit. my sig is the best pitrure that i have of them
I used the Ness kit also, nice setup for the price. As others stated, you should not have any added clearance issues. The only issue I had after the install was the brake pedal. The kit moves everything straight forward, since the pedals operating angle did not change it was a bit harder to fully depress (think having to point your toes/foot down). Probably not a really big issue for most, but I have a screwy ankle. My fix was to add a spacer to the master cylinder to adjust the pedals start point so it is a bit closer to me.
I've got the Arlen Ness 3" extensionson my 07 Deuce, though my pic is prior to that install. I'm 6'2" and they are great, one of the best things i've done. When i first had them installed i thought they might be a touch far away but 6 months or so later i'm thinking i could almost manage them being anohter inch or so away so i can really stretch out - not to say i'm cramped now.
i think longer term i might look at a full controls replacement rather than just the extension kit, but the kit is so cheap it was hard to pass up. Best thing i've done was to have the preload in the rear suspension set to accomodate my weight. If you haven't done that already i'd recommend it.
